It is currently Tue Aug 12, 2025 10:18 am
 Post subject: A test run
PostPosted: Wed Dec 30, 2015 7:03 am
First name: Brad
Last Name: Combs
Hello,
I'm buildings this first guitar as a gift. A late Christmas gift. [SMILING FACE WITH SMILING EYES]
I'm wondering if I can go ahead and install everything and string it up so that he can hear some sounds coming out of it and then take it back and put on the pore fill and finish? Could I just mask off the bridge and fretboard and remove the tuners later and then spray the finish on?
Thanks!
Brad
 Post subject: Re: A test run
PostPosted: Wed Dec 30, 2015 8:06 am
Sure you could. Cumpiano often used to list guitars on his website for sale "in the white" meaning they were set up and playable but without finish. He would stick the bridge on with just a little white glue and they remove it before finishing. It will end up adding time to the overall build, and there might be the chance , if you're like me, that finishing it will be put off for a long time to that it will get dinged dirty or stained in the meantime, but it could work of you really want it to.
Kent
These users thanked the author kjaffrey for the post: bcombs510 (Wed Dec 30, 2015 8:45 am)
PostPosted: Wed Dec 30, 2015 8:38 am
First name: Gregor
Last Name: Crothers
I played my first for quite sometime using the brass bolt kit (bridge) from stewmac.
It sounded and played just fine.
Kent is absolutely right, doing so delayed me from finishing for just over a year. Playing it was fun, worrying about learning how to French polish ..... not so much.
Gregor
Wake up and smell the rosewood!
These users thanked the author gregorio for the post: bcombs510 (Wed Dec 30, 2015 8:45 am)
PostPosted: Wed Dec 30, 2015 11:36 am
If dirt of finger oils get on the bare wood then finishing may be compromised. Also, are you sure you want to finish the top with the bridge already attached? That makes it a lot more difficult. I advise that you finish the guitar and then present it as an early gift for Christmas 2016.
PostPosted: Tue Jan 05, 2016 11:41 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Aren't classical guitars finished with the bridge glued on?
These users thanked the author ChuckH for the post: bcombs510 (Wed Jan 06, 2016 12:04 pm)
PostPosted: Wed Jan 06, 2016 8:34 am
Sometimes
Ken Cierp
These users thanked the author kencierp for the post: bcombs510 (Wed Jan 06, 2016 12:04 pm)
PostPosted: Wed Jan 06, 2016 11:59 am
First name: George
City: Seattle
Can it be done? Sure. Will it result in some unforeseen damage necessitating you to go back several steps and make repairs? Probably. Just sayin'. :D
George :-)
These users thanked the author George L for the post: bcombs510 (Wed Jan 06, 2016 12:04 pm)
PostPosted: Wed Jan 06, 2016 12:35 pm
I would put a few coats of shellac on first. Just the smallest bead of glue on the back edge of bridge. Careful not to get center seem separation when you take it off.
These users thanked the author Pmaj7 for the post: bcombs510 (Wed Jan 06, 2016 7:10 pm)
PostPosted: Wed Jan 06, 2016 9:29 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
I finish mine with the bridges glued on. I found it easier. I take a razor blade and scribe around the base of the bridge, not the top, before pulling the tape off. It seems to work just fine for me. I always had a hard time removing the lacquer or getting nicks in the finish trying to get a nice fit after finishing. I also tape off the fretboard area before until after the final sanding down. Then pull the tape off and spray the final coat over it to blend any area of lines from the tape.
Jason Moe
LaCrosse WI 54601
These users thanked the author JasonMoe for the post (total 2): ChuckH (Wed Jul 27, 2016 9:38 pm) • bcombs510 (Wed Jan 06, 2016 9:54 pm)
PostPosted: Thu Jan 07, 2016 3:47 am
That's some pretty wild bearclaw going on there [:Y:]
What's the B & S?
PostPosted: Thu Jan 07, 2016 9:19 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Ambrosia Maple B/S.
Jason Moe
LaCrosse WI 54601
These users thanked the author JasonMoe for the post: Colin North (Thu Jan 07, 2016 10:54 am)
PostPosted: Thu Jan 07, 2016 10:38 am
Jason, how do you level sand the finish and buff around the bridge? Any special tools?
PostPosted: Thu Jan 07, 2016 11:33 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
I use a soft sponge with wet sandpaper wrapped around it so it conforms to the slight radius of the top. I polish by hand with a soft rag. I dont have a buffing wheel setup yet.
Jason Moe
LaCrosse WI 54601
PostPosted: Thu Jan 07, 2016 3:56 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
State: British Columbia
If you want to attach a bridge to an unfinished guitar you can use these
http://www.stewmac.com/Luthier_Tools/To ... _of_4.html
Kerry
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
These users thanked the author kwerry for the post: bcombs510 (Thu Jan 07, 2016 4:02 pm)
Users browsing this forum: No registered users and 63 guests
